Activity › Forums › Adobe Premiere Pro › translation required Aanarav
  • translation required Aanarav
    Posted by Baz Leffler on January 18, 2006 at 2:13 am
    This from CreativeCOW Premiere Pro 2 review by Aanarav Sareen…
    “Other enhancements in this category include the long desired “Time Code” effect”
    The only timecode effect I want is the real time burn in on output.
    Eric Jurgenson replied 20 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    January 18, 2006 at 3:14 am
    Not sure what you mean. But there is a timecode effect, where you can apply it to a sequence, clip or transparent video.
  • Tim Kolb
    January 18, 2006 at 6:19 am
    That’s what Baz means…
    …and that’s what Aanarav means.
    It’s an effect you have to put in, but you can do a timecode burn. I’m personally jazzed that I can have a TC window on an MPEG 1 proof if I need to…not just tape.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Brian Deviteri
    January 18, 2006 at 11:10 am
    This was possible with DV Date and similar plug-ins in the past, but having it built right into the application will make things easier for a lot of people.
  • Eric Jurgenson
    January 18, 2006 at 1:21 pm
    Is it real time or does it need to be rendered?
  • Aanarav Sareen
    January 18, 2006 at 7:24 pm
    It has to be rendered for the final output.
  • David Cherniack
    January 18, 2006 at 9:38 pm
    Eric, you’re on Axio, right?
    Matrox has been asked to make this real time in the future. It shouldn’t be too hard.
    David
    AllinOneFilms.com
  • Eric Jurgenson
    January 18, 2006 at 10:10 pm
    Cool. That will be a real time saver.
