Activity Forums Adobe After Effects Expressions Translate Track Data from a 1920px comp to a 3840px one
  • Translate Track Data from a 1920px comp to a 3840px one
    Posted by Mauro Achille on March 29, 2018 at 3:08 pm
    Hi! I have track data from Mocha in a layer (corner pin, position, scale and rotation properties). The composition is a 1920 x 1080 resolution. I need to translate that same track data to a 3840×2160 comp. Everythings stays the same, it only changes the size of the image. Is that possible?
    Ross Shain replied 8 years, 1 month ago 3 Members · 3 Replies
  • Jacob Roth
    March 29, 2018 at 4:53 pm
    Try this on every effect.
    value*2
  • Mauro Achille
    March 29, 2018 at 7:05 pm
    Beautiful! thanks a lot!
  • Ross Shain
    July 17, 2018 at 4:38 pm
    Also note that Mocha projects will auto-scale to the size of the clip you give it. This is quite useful when working at 4k or 360/VR projects.
    For example, you could start a project at 1920, do the Mocha work, then link it to larger sized clip and the tracking and roto layers will scale.
    In the Mocha Pro plug-in this would be done by simply copying the plug-in from one comp to the other.
    In Mocha AE, you would save the Mocha project than open it on the other clip.
    Ross Shain
    Boris FX / Imagineer Systems
    https://borisfx.com/products/mocha/
