Activity Forums VEGAS Pro Transitions?
  • Transitions?
    Posted by Artemij Voskobojnikov on October 19, 2010 at 5:31 pm
    Hi all recently I found this video https://www.youtube.com/watch?v=zlcCxG_UIRE and i really like the editing especially those transitions (0:07 for example). I searched for about 3 days but I didnt find how to make them or how they are called to download em. I can create similar things with pan & crop but it still looks different.
    May someone help me with the name of those trans used in the video or may someone tell me how they are made?
    Regards
    Edward Troxel replied 15 years, 11 months ago 5 Members · 6 Replies
  • Theo Van laar
    October 19, 2010 at 5:58 pm
    This looks very much like the BCC Swish Pan Transition
    https://www.borisfx.com/Documentation/BCCSwishPan.pdf
    Theo
  • Artemij Voskobojnikov
    October 19, 2010 at 8:01 pm
    okay thank you, so I need Adobe Premiere Pro. I was already wondering where the guy got those trans from 😛
  • Theo Van laar
    October 19, 2010 at 8:37 pm
    No, you don’t need Premiere Pro to use theSwish Pan Transition. BCC is also available for Vegas:
    https://www.borisfx.com/sony/bccsvp/
    You can try the trial version of BCC for Vegas. In the past you could purchase Swish Pan Transition as a BCC unit. I’m not sure whether it is still available as a unit since it is not in the list anymore. But anyhow, if you want to use the BCC unit in Vegas, you need at least Boris FX as a plugin.
    Theo
  • Mike Kujbida
    October 19, 2010 at 8:39 pm
    Theo, you beat me to it 🙂
    I’ll just add that you need to be using Vegas Pro 10 to be able to use BCC directly.
  • Jonathan Thomas
    October 19, 2010 at 11:49 pm
    Also, you can create that same effect inside your camera. With a out focus and brace yourself and pan quickly 180 degrees. There you have it!!!
    Futhermore, play with your shutter speed.
  • Edward Troxel
    October 20, 2010 at 2:44 pm
    It could also have been NewBlue Motion Blends.
    Edward Troxel
    JETDV Scripts
