Activity › Forums › Apple Final Cut Pro Legacy › Transitions to multiple clips
  • Transitions to multiple clips
    Posted by Richard Rodriguez on September 20, 2007 at 2:25 pm
    Hello,
    I am sure this is not complicated, but I can’t seem to figure it out.
    I have over 100 images and want to apply the same basic dissolve to each of them…at the beginning and the end.
    Is there an easier way to do this other than each one individually.
    Thank you in advance,
    Rich
    BIG RICH
    Rafael Amador replied 19 years ago 2 Members · 1 Reply
  • Rafael Amador
    September 20, 2007 at 3:00 pm
    I think is enough to open the transition in the Brownser window and set the values. Select the whole sequence, and drag and drop the transition from the Brownser window.
    If this doesnt work, was an old system: Set the transition that you want apply as the “Default transition”. Select the clips from the time-line and drag to the “Overwrite with transition. You will get the transition in all the cuts.
    Cheers,
    rafael
