Activity Forums Apple Final Cut Pro Legacy Transitions on graphics not working properly
  • Transitions on graphics not working properly
    Posted by Doug Olin on June 15, 2005 at 12:24 am
    Since upgrading to Final Cut Studio I’m having problems with alpha channel graphics working with transitions other than cross dissolve. I apply an edge wipe to a graphic and instead of wiping just the edge of the graphic like it did in FCP HD, the entire screen is black until it completes the transition. Once the transition is complete the alpha channel works fine. If I try another transition, I get the same effect. However, on my parts of the timeline the transitions work as advertised. I have created some new graphics in FCP 5 to see if the age of the graphic was part of the equation but that doesn’t seem to be it. The cross dissolve is the only transition that works 100% of the time.
    I have dumped preferences and repaired permissions. Any ideas or is anyone else getting this same unacceptable result?
    Doug Olin
    Pensacola Christian College
    G5 DP 2.0, 2 GB RAM, FCP 5.0, IO, OS 10.4.1, Medea RT3X 1200 GB
    Gunner Jones replied 21 years, 2 months ago 3 Members · 3 Replies
  • Mark Raudonis
    June 15, 2005 at 1:01 am
    Was this project started in 4.5 and then opened in 5.0? If so, that may cause what you’re observing. We’ve noticed that there is some “wonkiness” with existing 4.5 projects that are brought forward to 5.0. It’s never a good idea to “cross over” versions. If possible start a fresh project in 5.0. If you already have a “clean”, new project, then I’m stumped.
    Mark
  • Doug Olin
    June 15, 2005 at 1:40 am
    This project was started in 4.5 and is now acting strangely in 5.0. I’m not sure why some of the transitions work but most don’t
    Doug Olin
  • Gunner Jones
    June 15, 2005 at 2:54 am
    Doug,
    Make sure you’re in Safe RT and High Quality in the RT Pop Up Menu and rendered at Full Quality in the Sequence>Render menus.
    O&O-Gunner Productions
    FCP-Avid-After Effects
