Activity Forums Apple Final Cut Pro Legacy transitions make footage “jump”
  • transitions make footage “jump”
    Posted by Elizabeth Kueneke on December 8, 2008 at 5:56 pm
    Hi there! It seems that there are more problems like mine out there and I´ve tried many of the solutions offered, but maybe there´s another idea out there. Every time I add a transition, whether it be a cross dissolve or wipe, or a fade-in/fade-out using the pen tool, a tiny jump is seen at the end of the transition. A little jump, or skip, or jitter. Anyway, I am using HD footage, PAL, on a MacBook Pro. Everything is fully rendered. Any ideas? thanks…..
    Elizabeth Kueneke replied 17 years, 9 months ago 2 Members · 2 Replies
  • John Sellman
    December 8, 2008 at 7:32 pm
    I had this going on too. I think by going to sequence>Redner All and make sure full is checked. I think that was the fix.
  • Elizabeth Kueneke
    December 8, 2008 at 7:37 pm
    I actually tried that and it wasn´t the problem. I did go to Sequence Settings and changed from Custom Frame Size 960 x 540 in HD to HD 960 x 720 and it seems to be working so far….thanks
