Transitions lost after compression
I’m editing with Final Cut Pro Studio 5.1.4 on a Mac Pro 10.4.10 and compressing with Compressor. No problems editing but some transitions like the Push transition works until it is rendered then it looks like a slide. The work around is to use the Push Slide transition instead which works fine but this is not my issue only a potential symptom.
The Push Slide, Cube Spin and the Spinback 3D all look good until I compress the video for DVD, then only the video I’m transitioning to spins or rotates, the remaining video dose nothing. Sometimes I can see an outline of the video moving but it is transparent. By the way, all of the other transitions or effects in the program work great.
I’ve tried using Quicktime for compressing, starting a new project with fresh video, changing the settings in compressor, scanning with the disc utility and of course re-booting but I can’t get any of those transitions to work properly after they have been compressed.
Thanks for any help!
Bruce
