Activity Forums Adobe Premiere Pro transitions jump at edit point
  • transitions jump at edit point
    Posted by Ron Pestes on September 4, 2011 at 7:58 pm
    I have a 1080/60p timeline that I have dropped a few stills into over the video. Every cross disolve from the video to the still and then back to the video has a verticle jump of a few lines. It jumps up at the start of the transition and then back down at the end. Any ideas as to how to get rid of this? I have tried changing the field dominance of the still but no luck. The timeline is native to the video.
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    New convert to Adobe CS5.5 Production Premium
    Ron Pestes replied 14 years, 8 months ago 3 Members · 3 Replies
  • Chris Buttacoli
    September 5, 2011 at 4:15 am
    Try moving the stills up onto video track 2 – or whatever the next higher video track is – and drop the cross-dissolve on the heads and tails of each, or manually animate their opacity in and out with key-frames.
    Whenever I have cross-fade issues, this seems to work.
  • Jon Barrie
    September 5, 2011 at 5:24 am
    can you let us know if this is happening with a render…
    Also do you have the Mercury Engine running in Software or GPU Hardware Mode?
    It could just be a quality “look” that happens when processing that section of the “effect” of transition being used but doesn’t appear when exported or rendered out.
    Let us know 🙂
    JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Ron Pestes
    September 5, 2011 at 4:17 pm
    Yes, all appears well after it is rendered out. It just happened when it was on the timeline. Thanks.
    Sony EX-3
    MacBook Pro
