Activity › Forums › Adobe Premiere Pro › Transitions include extra footage
  • Transitions include extra footage
    Posted by Deleted User on September 25, 2007 at 11:11 pm
    I am working in a nested sequence and want to place a simple cross dissolve transition between clips. The trouble is that when I do, a few frames from elsewhere in my project get added to the transition. This is obviously a problem but I don’t know why it is happening or what to do about it. Can anyone help?
    If we all did what we are actually capable of doing, we would astound ourselves. Thomas Edison
    Deleted User replied 18 years, 11 months ago 4 Members · 6 Replies
  • Harm Millaard
    September 26, 2007 at 7:43 am
    Start reading about Clip handles and transitions in the Help file.
  • Deleted User
    September 26, 2007 at 8:25 pm
    Thanks for the response. It is appreciated. I did look at the topic you suggested, but it doesn’t seem to match my problem.
    Here is my situation. I have taken a few clips from a longer video (I had to razor the original footage because the detect scenes function failed to work for some reason) and placed them into their own sequence (maybe this is the problem) to make a shorter “music video”. I planned to nest this sequence into the main sequence when the music video is completed. When I go to add the cross dissolve transition, I get no diagonal warning bars through it and no warning.
    I am completely stumped on this.
  • George Socka
    September 26, 2007 at 11:36 pm
    Try deleting preview files.
  • Deleted User
    September 27, 2007 at 12:20 am
    Thanks for the tip. I tried it and that didn’t seem to make any difference.
    Has anyone else had this problem? I am about ready to reinstall the whole program, but I don’t know if that would require me to reactivate or not.
  • Dasiroll
    September 30, 2007 at 9:57 pm
    Mate i have the same problem but i dunno how to resolve that i m been trying hard to resolve that but i cant menage 🙁 i tryed to re-install the premiere pro but without any results stills with extra frames 🙁
    Hopefully i wish someone can help us
  • Deleted User
    October 1, 2007 at 4:14 pm
    Das,
    I figured it out. I am kind of an idiot . . .
    My problem was this: when I razored my footage, I cut it exactly at the frame that borders the other clips. This didn’t leave Premiere any room to gently transition between the clips so it used the extra footage to fill in. My solution to this problem was to move the in/out points closer together to allow Premiere enough footage to transition without using extraneous frames.
    This completely fixed my problem.
