Activity › Forums › Avid Media Composer › transitions effecting other layers
Posted by Lori Miranda on December 31, 2009 at 5:31 pmHello,
I am trying to fade in a lower-third graphics with a title over a person speaking. I have done this a million times before but for some reason on this one it is dissolving the person talking as well as the title. Any ideas how to make the dissolve (or fade) only affect the title graphics and not the video underneath.
Thanks so much,
LoriLori Miranda replied 16 years, 7 months ago 5 Members · 8 Replies -
Lori Miranda
December 31, 2009 at 7:03 pmI tried that and still the same thing. It seems that any transition I do affects the bottom layer. Any other suggestions?
Ed Cilley
December 31, 2009 at 7:50 pmLori,
So let me see if I am following what is happening…
V2 – Graphic Title (not nested)
V1 – Video (interview)If you have a lower third on V2 and nest another title (title tool), it will look below to the bottom layer. Un-nest the effect if this is what is happening.
Is the lower third a Matte Key, or are you adding effects to get the key?
Ed
Avid and FCP Preditor
_________________________________________________
Anything worth doing at all, is worth doing well.
– Philip Dormer Stanhope, Earl of Chesterfield -
Lori Miranda
December 31, 2009 at 8:15 pmHi Ed,
So my V1 is my video. V2 is a lower third matte key. V3 is a title that I made. Nothing is nested right now. No matter what transition I use it affects the video on V1. Any help would be greatly appreciated.
Lori -
Randy Pfeiffer
December 31, 2009 at 10:27 pmHi Lori,
I use the “Effect Editor” and add keyframes to adjust foreground (transparancy) from 0% to 100% to create the transitions (dissolves)… You can also use the crop, position, scaling, etc. to add to your transitions.
Hope this helps,
Cheers,
Randy -
Lori Miranda
January 1, 2010 at 5:39 pmHi Randy,
Thanks for the help but when I adjust the foreground and such in the effect editor it affects my video on V1 as well. My problem is that I can’t seem to keep the title and lower-third matte separate from the video. Whatever transition I do on V2 and V3 affects V1 as well, which I don’t want.
Lori -
Hans Sieber
January 2, 2010 at 12:17 pmHi Lori,
what kind of lower third are you having on V2? Is a imported real time moving matte or did you get fill and alpha seperately and combined them in the timeline with the matte key effect? If you open the nest of your lower third the alpha should be in V2.3. On which layer is the fill? V2.2 or V 2.1? In my case putting the fill on the other layer V.2.2 rather than V2.1. made it work. Had the same problem as you do.
Hope I could be of help.Yours
Hans -
Lori Miranda
January 4, 2010 at 4:48 pmIt’s a real time moving matte so I didn’t apply an alpha. It already had one.
