Activity › Forums › Adobe Premiere Pro › Transitions do not render with multicam sequence
  • Transitions do not render with multicam sequence
    Posted by John Kary on February 29, 2008 at 1:39 pm
    I have had this problem since Premiere Pro 2.0, and am now on 3.1.1 and it still occurs.
    I will have cut my multicam sequence with no problems, and then want to add simple fade-in and fade-out transitions to the head and tail ends. I tried this using the Cross Dissolve effect by dragging and dropping it both on my nested sequence (where all the multicam cuts appear), and within the sequence itself that contains 3 video tracks of video that I cut between.
    After applying the transition in either of these cases and running File > Export > Movie, the transition is not in the final output! It shows the fade-in and fade-out in the normal reference monitor within Premiere, but doesn’t show in the final output.
    I have tried rendering my sequence within Premiere so there is a green line above the transitions in the timeline, indicating that footage has been rendered. Still nothing.
    Is this a bug or could I be doing something wrong?
    John Kary
    Titus Films
    https://www.titusfilms.com
    John Kary replied 18 years, 7 months ago 2 Members · 2 Replies
  • Shawn michael Lee
    February 29, 2008 at 8:35 pm
    It may be a bug. Have you tried creating black video and then putting it at the head and tail of the sequence or the clips? Then dissolve from/to the black clip. If you tried this, nevermind.
    BTW, I suggest this because it is exactly what I have to do to get the sequence to work in AVID Adrenaline MC.
  • John Kary
    March 1, 2008 at 6:56 am
    Shawn,
    Adding a layer under the multicam nested sequence and putting a black BMP under it solved the crossfade not showing up. I applied the cross dissolve to the multicam sequence and it now shows in export. Thanks for the help!
    John
