Activity Forums Adobe After Effects Transitions Ae/Pr
  • Transitions Ae/Pr
    Posted by Polonha Patrick on April 19, 2017 at 1:10 am
    As you can see above, I have an “image” and wanted to use a transition to Image “B” (illustration)
    Well, the transition that I’m using as an example is a black line, just for example!
    I wanted the black line slipping diagonally cutting the Image “B” and appearing to “image”, until then I can’t do it quietly.
    The Problem: all right, I know how to make the transition in after effects, but to play another image inside the “image” I have to redo all the transition upon this new image. I even tried to do pré-comps to simply replace the image within the program, but then I have to keep adjusting cutting, taking piece of video, well … it’s not very agile if you know what I mean …
    Is there any way to be able to simply drag a video to the timeline of the premiere itself into the transition done in after? Type … Dragged-and-dropped and the “image” is replaced?
    Tudor “ted” jelescu replied 9 years, 4 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    April 19, 2017 at 8:54 am
    from your example I do not see why you can not use Premiere to do the transition – you can have a line in between transitioning clips, like in your example, with control over the color and thickness of it. Maybe I am missing something…
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
