Activity › Forums › Adobe After Effects Expressions › Transitional colors
  • Transitional colors
    Posted by rica maru on June 28, 2021 at 12:31 pm
    I’m setting a way to animate some colors changes, like I have my main colors on my main layer so I can define them and then I set a linear expression so I can make color 1 change to color 2 in a gradient fashion.
    Color1 = comp(“main”).layer(“Color_crtl”).effect(“Color Control_06”)(“Color”)
    Color2 = comp(“main”).layer(“Color_crtl”).effect(“Color Control_02”)(“Color”)
    linear(effect(“Slider Control”)(“Slider”),0,100,Color1,Color2)
    But would be possible to be able to change for multiple colors? Like is there a way to setup the slider so the value 01 goes to color 01, value 10 goes to color 05, value 20 goes to color 03…
    I saw some stuff from @andrei popa, but in his resolution the colors just swap, I’d like them to be animated.
    rica maru replied 5 years, 3 months ago 2 Members · 4 Replies
  • Andrei Popa
    June 28, 2021 at 1:56 pm
    Try this:
    c1=thisComp.layer("Color Control").effect("Color Control")("Color");
    c2=thisComp.layer("Color Control").effect("Color Control 2")("Color");
    c3=thisComp.layer("Color Control").effect("Color Control 3")("Color");
    c4=thisComp.layer("Color Control").effect("Color Control 4")("Color");
    slider = thisComp.layer("Color Control").effect("Slider Control")("Slider").value;
    myColors = [c1,c2,c3,c4];
    vals = [0,10,20,30];
    i = 0;
    while(i<vals.length-1 && vals[i]<= slider){
    i++}
    linear(slider,vals[i-1],vals[i],myColors[i-1],myColors[i])
  • rica maru
    June 28, 2021 at 2:10 pm
    Now that’s something special. Thank you very much!
    I want to get better at expressions, is there a course/tutorial series that you could point me at?
  • Andrei Popa
    June 28, 2021 at 3:01 pm
    Sergei Prokhnevskiy from Ukramedia has some really nice tutorials on Youtube. If you like those, you may consider buying his course on expressions.
  • rica maru
    June 28, 2021 at 5:05 pm
    Cool tks, I’ll take a look at that.
    Cheers
