Activity Forums VEGAS Pro Transition with Track Below
  • Transition with Track Below
    Posted by Mark Thompson on February 22, 2012 at 9:03 pm
    an easy question 🙂 I have a 4 minute clip of someone playing an instrument, obviously the sound is nicely synchronized with the pictures. I want to add some clips on top of that track to give the effect of the musician viewed from different angles. For these clips there is no synch but I hope that people will not notice he’s playing a different tune (ok so that is wishful thinking but perhaps if I keep these clips short enough). That all works like a charm but … I would like the clips on top to transition with the track below. e.g. I would the clip on top to cross fade in and cross fade out as it would do if it had an adjacent clip.
    All I can think of is a transparency envelope or slicing up my in synch track with gaps big enough for the clips above.
    Are there any better ways?
    thanks
    Mark Thompson replied 14 years, 6 months ago 3 Members · 3 Replies
  • Joseph Tessier
    February 22, 2012 at 9:45 pm
    Mark, I believe you just place your cursor at the top edge of the clip in question and when your cursor changes to the arc “Fade Offset” you just click/drag an appropriate amount of time.
    J. Paul
    System Specs: I7 3.4 Ghz Quad Core 16GB Ram Win 7 Home Prem x64 VP 10/11 NVIDIA GeForce GTX 550
  • Mike Kujbida
    February 22, 2012 at 9:52 pm
    Fade the clips on the upper track in and out and you’ll get the effect you want.
  • Mark Thompson
    February 22, 2012 at 11:11 pm
    thanks very much, things are much smoother now. I was convinced transitions needed two adjacent clips.
    mark
