Activity Forums Adobe After Effects transition question
  • transition question
    Posted by Matthew Mcnulty on April 21, 2008 at 11:51 pm
    I have two zaxwerks text object in the time line… i want to transition from the first object to the second object using a lens flare type of effect… the lens flare effect seemed lacking, perhaps i am missing something…
    not a flash frame per se, but more like a quick (ramping brightness) light, very quick… all suggestions, tips tricks or tutorials welcomed…
    thanks o’ton
    Matthew Mcnulty replied 18 years, 5 months ago 2 Members · 2 Replies
  • Chris Kelley
    April 22, 2008 at 12:43 am
    Try creating an adjustment layer at the top of your timeline with the Glow effect applied, and then ramp up the intensity of your glow, or you could also ramp the opacity of your adjustment layer. This may give you more of the camera flash you’re looking for.
    hth
    Chris
    showreel: https://chriskelley.tv/work/
    https://themographblog.com
  • Matthew Mcnulty
    April 22, 2008 at 4:27 am
    nice!
    thanks bro!
