Activity › Forums › Apple Final Cut Pro Legacy › Transition Question
Transition Question
Posted by Pete on July 24, 2006 at 9:16 pmHey guys, if i wanted to use a clip’s Alpha, or an Alpha i made as a transition in Final Cut Pro, how would i do that?, you know like the Step in AVID, and adding the alpha to the clip that you want to transition), thanks.
Pete replied 20 years, 2 months ago 3 Members · 4 Replies -
Bouncing Account needs new email address
July 24, 2006 at 9:35 pmYou can use any alpha channel image (a Title, a Photoshop image with alpha, etc) to cut a HOLE (in it’s exact shape) and “Fill” it with other moving (or static) video… all “keyed over” another video track.
V3: Fill clip (what you want to be “inside” alpha)
– Select (highlight) THIS clip on V3, then:
Modify (menu) > Composite Mode > Travel Matte – AlphaV2: Any “Alpha-channeled” clip (or title generator)
V1: Background clip (will be seen outside the “hole(s)”)
If you end up with the “reverse” of what you want, swap the clips on V1 and V3.
Remember to change the settings (Modify (menu) > Composite Mode > Travel Matte – Alpha) on the clip that is now on V3.You can move/expand/reposition the V2 clip or even use it as a custom “wipe”.
Arnie Schlissel
July 24, 2006 at 11:36 pmyou can use a grayscale image in the gradient wipe transition to do this. Should be in the manual.
Arnie
Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
https://www.arniepix.com -
Pete
July 25, 2006 at 2:15 amyou guys are all talking about a static image though (i think), i’m talking about a clip of moving video, i mean let say that i’ve made an animation as a transition element, but to make it a bit more seamless, i’d like to use the alpha chanel of that same animation, to mask the transition. that’s what i’m talking about, i know about the gradient map, i just thought you could do almost the same but with a moving clip.
Thanks.
Pete
July 25, 2006 at 2:17 amthanks Matte, i think you answered it, i really appreciate all them help. will try tomorrow.
