Activity Forums Apple Final Cut Pro Legacy Transition problems w/FCP 5.0.2 and 59.94 720p
  • Transition problems w/FCP 5.0.2 and 59.94 720p
    Posted by Matty@switch on October 5, 2005 at 3:36 am
    Hey everyone,
    Anyone else having this issue?
    We’ve recently gotten a lot of work with 720p material coming off of D5. While FCP 5 has been running
    normally with the 1080i and 24p material we have been working with, the 59.94 720p stuff seems to
    be creating issues with simple transitions such as dissolves and fades to black.
    Our edit has numerous fade to blacks or really dip to blacks, as the client wants to immediately fade up
    into the next shot. Placing a dip to color on the timeline results in an immediate CUT to black at the
    head and tail of the transition. We have tried to work-around by fading to black, adding a frame of black
    between the two shots, and then another fade up from black. Same results: a CUT to black. They do not
    render correctly, nor do they scrub correctly. Nor will they park on a frame in the middle of the transition
    showing only black while in the area of the transition. What gives?
    Another problem we are having is dissolving from a frame of white… perhaps this is a problem with my
    workflow. I am using the built-in effects video generator to make a white rectangle, cutting it into the
    timeline, then trying to dissolve from the rectangle to the next shot. Invariably, the cross-dissolve
    goes from the white frame to black, then cuts to the first frame of picture after the transition. Seems
    like this is related to the aformentioned problem… What do you think?
    I have reinstalled my Blackmagic drivers, trashed preferences, cleared the PRAM and pulled out a lot of
    hairs in the process of debugging this. Incidentally, my workaround has been to export the XML and open
    the job in FCP 4.5 where the transitions perform flawlessly. Not exactly an elegant solution, but what
    can you do when your client is breathing down your neck?
    Any help would be greatly appreciated!
    Matt
    MY System Specs:
    Dual 2.5 G5 w/ 2.5gb ram
    OSX 10.4.2
    Quicktime 7.0.2
    Blackmagic 5.1
    FCP 5.0.2
    XRaid 2.7T
    Apple Fiber Channel Car
    Jeremy Garchow replied 20 years, 11 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    October 5, 2005 at 3:50 am
    What codec are you using? Have you tried deleting your render files?
  • Matty@switch
    October 5, 2005 at 4:09 am
    I’m using Blackmagic 8-bit w/photo jpeg compression… now I know what you’re thinking… that there’s
    something funky w/photo jpeg, but I get the identical results w/ material that is uncompressed.
    I have deleted the render files, and changed my default transition (someone suggested that). Also,
    I have noticed I get black whenever I adjust the opacity of a layer to anything but 100%. That certainly
    seems related…
    MY System Specs:
    OSX 10.4.2
    Quicktime 7.0.2
    Blackmagic 5.1
    FCP 5.0.2
    XRaid 2.7T
  • Jeremy Garchow
    October 5, 2005 at 5:55 am
    Try creating a new project and set up a new sequence with the proper sequence settings. Select all in the problem timeline then copy & paste these clips into the new timeline in the new project. If that works select everything in your browser short of the timeline that is giving your problems and paste it all into the new project.
    Just for yuks, have you tried importing that xml into a new sequence in FCP in your current project?
    You do have heads and tails on your clips, correct? Did you upgrade to Tiger or do a clean install? If you did not do a clean install it is highly recommended. It sounds like a funky configuration or upgrade anomaly to me, but this is just a guess without being able to see your timeline.
    Jeremy
