Activity › Forums › Apple Final Cut Pro Legacy › Transition problem with stills using ‘Wind Blur Cross’ FCP 7
  • Transition problem with stills using ‘Wind Blur Cross’ FCP 7
    Posted by Nico Scott on May 28, 2012 at 9:23 am
    Hi all,
    I’ve been sitting here racking my brains over this one for the last 3 hours and can’t seem to fix the problem. I’ve been using Too Much Too Soon’s ‘Wind Blur Cross’ as a transition between still images (tiffs on a transparent BG, no layers).
    I’ve used the transition across about 15 different sequences with no problems and I’ve just had the client replace two products and for some reason when I drop these in and add the above transition FCP throws up random short/thin black lines but only after I render, if I step through the footage before I render it, it’s fine.
    I’ve tried saving the stills in different formats, with and without alpha channels, different comp modes, nesting the stills and all to no avail. I’m starting to think there’s a problem with the stills, maybe a corrupt data or the like, but they do appear to be the same as all the others…
    Any suggestions would be much appreciated as I’ve got 18 retail TVCs i’ve got to get out the door asap!
    many thanks
    Rafael Amador replied 14 years, 4 months ago 2 Members · 1 Reply
