Activity › Forums › Apple Final Cut Pro › transition problem
transition problem
Posted by Joe Brown on April 30, 2016 at 11:17 amI have been adding transitions between clips for a while, but now the transitions will not go between individual clips. When I bring over a transition to a clip the whole clip is highlighted, not just the line between the clips, and then the transition is applied to a group of clips. furthermore, a black box is now clumping together the three clips that have the two transitions. What happened? I don’t want the clips grouped together with a black box and I only want the one transition.
Mark Suszko replied 10 years, 4 months ago 6 Members · 6 Replies -
Jeff Kirkland
April 30, 2016 at 2:12 pmOn the primary storyline? Sounds like either you’re not selecting the end of the clips properly so it’s highlighting the entire clip and adding a transition to both ends or it’s time to reinstall Final Cut Pro. If you’re talking about connected clips them the black box is a secondary storyline.
A screen shot would probably help us see what’s happening.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Joe Brown
April 30, 2016 at 2:43 pm -
Noah Kadner
April 30, 2016 at 3:22 pmThat’s a secondary storyline- required to create transitions between clips connected to the primary storyline.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops -
John Rofrano
April 30, 2016 at 5:01 pmIt appears that you are trying to create a transition between connected clips which is why you are seeing this behavior.
I have to ask… From your screen shot we can see that your Primary Storyline is empty. Why is that?
What happened is that your clips were not on the primary storyline. They are just Connected Clips above an empty primary storyline. In order to add a transition between clips, they have to be on a storyline so what FCP X did was create a secondary storyline for you. In addition, you probably selected the clip in the middle and dropped a transition on it which by default, adds the transition to both the head and tail of the clip which required creating a secondary storyline from three clips: the selected clip, the clip before it, and the clip after it.
If you want the transitions to behave as you expect, you should have your clips on the primary storyline and then Command+Click (⌘+click) just the edge that you want the transition applied to before you add it.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
Nick Toth
May 2, 2016 at 12:47 pmYou don’t need to Command click on the edge. Just click on it.
Also you can position the playhead or skimmer between two clips and use the bracket keys:
[ = select left edge
] = select right edgeAn upcoming video from FCPExchange will have Steve Martin doing an entire edit without touching the mouse. Looking forward to that one.
Mark Suszko
May 3, 2016 at 8:50 pmThis is totally NOT a bookmark to find out when that tutorial actuates:-)
