Activity Forums Adobe Premiere Pro transition makes colored stripes
  • transition makes colored stripes
    Posted by Hannes Denker on August 10, 2010 at 2:54 pm
    hello everybody,
    i’m new to premiere pro. working with ppro cs5. now here’s the problem: when i make a transition between 2 clips, there occur vertical colored stripes on the right side of the image. i think it has sth to do with the sequence settings but don’t know… please somebody help! thx!
    Hannes Denker replied 16 years, 1 month ago 3 Members · 3 Replies
  • Ann Bens
    August 10, 2010 at 5:36 pm
  • Vince Becquiot
    August 10, 2010 at 10:34 pm
    I did notice this when working in SD square pixel sequences. For example 854×480 square, going to 864×480 made it go away. What are your sequence settings?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Hannes Denker
    August 11, 2010 at 11:42 am
    hey guys thx for your reply!
    sequence settings: 702 x 576 (1,09) 25fps p (if you wonder about the pixels… terrible footage but whatever)
    btw: i forgot to mention that the problem only occurs with transitions from black or to black. first tried the preset, didn’t work. then tried soft transition with the background black, didn’t work either. so build me a black background in ps, imported to ppro, guess what, didn’ work. finally found the colored mask in the project window, which finally solved the prob. so now it works.
    anyway, i’d still like to know the reason for this prob… cause even though it works now, my solution is not very elegant…
    thx!
