Activity › Forums › Apple Final Cut Pro Legacy › Transition levels jump
  • Transition levels jump
    Posted by Richard Marsh on June 17, 2009 at 6:34 pm
    Edge wipe transitions are brighter than the two graphics I’m transitioning between. They are both keyed over moving BG. I realize AfterFX can do this no problem, but does anyone know a work-around in Final Cut Pro?
    Richard Marsh replied 17 years, 3 months ago 2 Members · 2 Replies
  • Kevin Monahan
    June 17, 2009 at 6:52 pm
    Do you have Sequence > Render > Full engaged?
    Are you looking at the results on an external monitor or computer screen?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Richard Marsh
    June 17, 2009 at 8:35 pm
    Yes, sequence/render/full is turned on. And yes, I’m viewing on computer monitor as well as NTSC monitor. The 2 graphics I’m wiping between are TGAs with alpha channels. The BG is a motion graphic. I had this problem before. I was able to nest the graphics to the BG (a solid white) and do the transitions. The key here is Final Cut’s ability to do a key and a wipe simultaneously. Thanks.
