Activity Forums Apple Final Cut Pro Legacy Transition Glitches
  • Transition Glitches
    Posted by Justin M on June 14, 2007 at 1:51 pm
    I’m having a problem I hope someone can help me with. There are a couple of transitions (both fades to black of longer than 1 second) in a project I’m working on that play smoothly on the timeline without rendering, but jump back a few frames when I render or export them. I have tried using various transitions types and lengths but the problem occurs every time. Any ideas as to what’s causing it and how to fix it?
    I am using FCP 5.1 on a MacPro dual 2.66 GHz 2GB RAM
    Justin
    Justin M replied 19 years, 2 months ago 2 Members · 2 Replies
  • David Heidelberger
    June 14, 2007 at 4:36 pm
    See the June 9th thread below entitled “Strange Render problem with dissolves.” Are you working with P2 media? If so, that may solve your problem.
    – David
  • Justin M
    June 14, 2007 at 5:02 pm
    I am using P2 media, but at this point of the project I don’t want to mess around with re-importing it. Adding a gaussian blur set to 0 did the trick in both cases.
    Thanks a lot for your help. I’ve been searching the posts for days looking for that answer.
    Justin
