Activity › Forums › Adobe After Effects Expressions › Transition from Hex Color to another from CSV displayed in Text layer
  • Transition from Hex Color to another from CSV displayed in Text layer
    Posted by Gregory Graham on September 22, 2021 at 11:18 pm
    Hi there! I’m trying to make a template that would make a video which would transition from one color to another. The first and second colors would be loaded from a CSV. I’ll include a link to an example of what I would want the finished product to look like:
    https://youtu.be/EbNVcFyIGKo
    My issue is – this concept works when entering the colors manually as keyframes. When I try to enter the colors via an expression referring to a CSV, the text layer/color does not constantly update/transition.
    For reference, the expression in my Color layer referring to the CSV reads as follows:
    colorText = thisComp.layer("Gradient Gram - CSV.csv")("Data")("Outline")("Left Color")("Left Color 0").toString();
    hexToRgb(colorText);
    This is the first color, the second color in my CSV would be (“Right Color”)(“Right Color 0”). I tried unsuccessfully to keyframe to this change.
    Any thoughts/ideas/help would be greatly appreciated!
    Thank you!
    Gregory Graham replied 5 years ago 2 Members · 2 Replies
  • Fabrice Leconte
    September 24, 2021 at 3:36 am
    Hello,
    You can use a linear expression
    c1 = thisComp.layer('Gradient Gram - CSV.csv')('Data')('Outline')('Left Color')('Left Color 0').toString();
    // #000000
    c2 = thisComp.layer('Gradient Gram - CSV.csv')('Data')('Outline')('Right Color')('Right Color 0').toString();
    // #FFFFFF
    linear(time,0,10,hexToRgb(c1),hexToRgb(c2));
  • Gregory Graham
    September 24, 2021 at 9:18 pm
    This worked perfectly, thank you so much!
