Activity › Forums › Adobe After Effects › Transition Effect
  • John Cuevas
    November 1, 2013 at 11:43 am
    It would take a combination of effects to do everything they are doing there. Noise/displacement maps/masking, maybe even screening some actual noise over the video.
    First check out the Bad TV presets, if you want to create something like that, see if they create the look you need. Also the noise effect generates noise. There are a couple of plugins also that can be used to create this effect. VideoCopilot Twitch and Bad TV scripts.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
