Activity Forums Apple Final Cut Pro Legacy Transition Duration changes when added to timeline
  • Transition Duration changes when added to timeline
    Posted by Eric Holzapfel on May 15, 2009 at 4:45 pm
    Hello There,
    I have done some looking on the forum, but have not quite found an answer for this one. I have copied my “Cross Dissolve” video transtion for FCP (Cross Dissolve Copy). I added the “Cross Dissolve Copy” to my Favorites in the Effects tab. I have changed the duration for the Cross Dissolve and the copy to 20 frames. Or so I thought. I have set this for my default transition.
    I like to believe I am smart, and use Command-T to add a transition to the edit point on a clip. When I do this the duration is 25 frames!
    I then have to change the duration to 20 frames manually (right click, etc). I am working with a NTSC 720×480 sequence, using still images.
    The transition shows as 20 frames in the Effects area. Is there something in the sequence properties that might cause this?
    Thanks for a great source of info,
    eric
    P.S. I did create a temporary nightmare for myself by trashing my FCP preferences – I was able to recover, but the story is too long to post on the forum.
    Eric Holzapfel replied 17 years, 3 months ago 2 Members · 2 Replies
  • Joey Burnham
    May 15, 2009 at 4:56 pm
    after you change the duration in the browser, right-click on the cross dissolve and set to default transition. if i remember correctly you have to do both, even though it’s already underlined as the default.
  • Eric Holzapfel
    May 15, 2009 at 7:21 pm
    Hello Joey,
    I am pretty sure I did that, but… I will follow your tip to be sure!
    eric
