Activity Forums Apple Final Cut Pro Legacy Transition Bug
  • Posted by Dirk Bullard on March 17, 2009 at 6:55 pm
    I recently upgraded to 6.0.5. All new projects do not allow me to Option click on a dissolve already on the timeline and drop it on other clips in the timeline. Also, if I double click a dissolve to open the viewer window I can’t grab the “hand” and drop it on other clips in the timeline. I can’t save any transitions in Favorites (except the default cross disolve) because they all change to 1 frame. Copy/Paste doesn’t work with dissolves either. This isn’t a problem on older projects that I created before the upgrade. Ideas????
    Victor Perez replied 17 years, 5 months ago 3 Members · 3 Replies
  • Jerry Alto
    March 17, 2009 at 7:40 pm
    Dirk- When I’m tired it is usually from lack of sleep. When I can’t do transitions it is usually from lack of slop. Can you say handles?
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
  • Dirk Bullard
    March 17, 2009 at 8:03 pm
    It’s not a handle problem. Plenty of room on both sides. It happens with video, pics, and grfx.
  • Victor Perez
    March 17, 2009 at 10:12 pm
    It seems like you have a lot of prefs on how you like to work like I do. When I updated to 6.0.5 I had plenty of strange things happening with FCP and I had to recreate my window settings. Things cleaned up a lot, but I still decided to delete my prefs and start anew.
    Try this:
    click Control U
    that will get you on the Standard FCP window layout. Try doing what you couldn’t before like save a transition. If you can now then I would recreate new window settings in FCP 6.0.5.
    If the problem persists you probably have to delete your prefs and create new ones in FCP 6.0.5
    good luck,
    Victor
