Activity Forums Apple Final Cut Pro Legacy transition between two cuts
  • Bill
    May 1, 2005 at 7:59 pm
    i have done this many of times using the eurkeka chroma glow paired up with silk stocking and then key frame your birghtness to blow out the chroma glow. then save it as a favortie set up…… hope this helps
  • Max Frank
    May 2, 2005 at 1:21 am
    #1 – there’s an easier way – simply download the free ‘Vapor blur’ from Eureka plug ins.
    #2 – I believe it’s Bob Hoskins, not Anthony 🙂
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
  • Bill
    May 2, 2005 at 12:19 pm
    You cant give the answer away that easy……….
