Activity Forums Adobe After Effects Expressions Transition between condition statements
  • Transition between condition statements
    Posted by Baard Kolstad on September 2, 2016 at 12:23 pm
    I’m creating this equalizer, and I’m trying to get the different bars to change color depending on the value of the sound they are connected to. The code below is what I have so far.
    Now, it is working. The only thing it is lacking is that it is not transitioning between the different states. So what I’m looking for is a gradient transition between the different if/else conditions. I could of course manually just set more else if statements, but that would take too much time.
    soundValue = Math.floor(thisComp.layer("Medium Gray-Magenta-Red Solid 17").effect("Sound Keys")("Output 1").value);
    if (soundValue >= 570)
    [0,0,1,1]
    else if (soundValue >= 200)
    [0,1,0,1]
    else
    [1,0,0,1]
    Dan Ebberts replied 10 years ago 2 Members · 3 Replies
  • Dan Ebberts
    September 2, 2016 at 1:28 pm
    Something like this maybe:
    if (soundValue > 200)
    linear(soundValue,200,570,[0,1,0,1],[0,0,1,1])
    else
    linear(soundValue,0,200,[1,0,0,1],[0,1,0,1])
    Dan
  • Baard Kolstad
    September 2, 2016 at 1:54 pm
    Thanks Dan! Seems to be working. Is there a way to convert hex values to the 0-1 rgba system? Can’t find any converters online.
  • Dan Ebberts
    September 2, 2016 at 4:07 pm
    There may be something simpler, but this should work:
    myColor = 0x75ff20;
    r = ((myColor & 0xff0000) >>> 16)/255;
    g = ((myColor & 0xff00) >>> 8)/255;
    b = (myColor & 0xff)/255;
    [r,g,b,1]
    Dan
