Activity Forums Adobe After Effects Transition between 2 layers – not transparency
  • Transition between 2 layers – not transparency
    Posted by David Robinson on January 17, 2006 at 12:25 am
    I thought I had this figured out a long time ago, but I’ve hit a wall. I have 2 green screen layers that have been keyed with Keylight. How do I create a dissolve between them without seeing the background? Using opacity shows the background. I’ve tried several options including Effect – Channel – Blend. Thanks for any advice you can send my way.
    David Robinson replied 20 years, 8 months ago 2 Members · 2 Replies
  • Antony Buonomo
    January 17, 2006 at 12:40 am
    try pre-comping each layer and then the opacity transition on these layers
  • David Robinson
    January 17, 2006 at 1:36 am
    Thanks Antony. Pre-comping still didn’t work with animating opacity, but I was able to use Channel – Blend. It wouldn’t work before because choosing the layer in Blend was using the layer without Keylight. The pre-comp fixed that. Thanks!
