Activity › Forums › Apple Final Cut Pro › Transition Behaviour
  • Transition Behaviour
    Posted by Gregor Queck on September 24, 2018 at 6:37 pm
    I’m probably just to stupid but how can I get the old transition behaviour to shorten the media??
    Thank you!
    ”Conversations don’t have to be easy to be worthwhile”
    Jordan Peterson
    Jeff Kirkland replied 8 years ago 2 Members · 1 Reply
  • Jeff Kirkland
    September 24, 2018 at 8:44 pm
    Not 100% sure what you’re asking but an FCPX transition is either centred around your edit point or, if there’s not enough frames in one or both clips to do that, will warn you and move the edit point to create enough frames for the transition to be added.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
