Activity Forums Adobe Premiere Pro transition adds frames frames
  • transition adds frames frames
    Posted by David Jelley on November 30, 2005 at 10:57 am
    I have cut two clips butted to each other and then added a transition. PP then seems to add back frames to the clips. Is this normal, if so, I would have to cut back ? frames to compensate for this. Can any one explain this problem.
    Thanks David
    David Jelley replied 20 years, 9 months ago 2 Members · 2 Replies
  • Mike Velte
    November 30, 2005 at 1:09 pm
    You are correct in what Pro does…adds 15 ( on a 1 sec trans) frames to the out point of the first clip and 15 to the in point of the second clip. In a perfect world, the editor makes the decision to add a transition while cutting the clips in the source window and then cuts it appropriatly, knowing what the “extra” frames are.
  • David Jelley
    November 30, 2005 at 3:20 pm
    Thank you for your reply Mike now I know what to do. David
