Activity › Forums › Apple Motion › Transforming still objects in Motion 5
  • Transforming still objects in Motion 5
    Posted by Malgorzata Wojtunik on June 22, 2014 at 8:09 pm
    Hi guys,
    I’ve been struggling for a long time with this issue, trying to figure it out on my own, but I am the Motion 5 newbie and I think I need your help.
    I want to make animation of a neck cord. This neck cord will have some picture on it and I want it to unfold, scale in and move through the pictures. I managed to create a bazier mask that does that ( You can see the animation here: https://youtu.be/GUtv72TNxKE – I know it’s not perfect, but this is more or less what I need to do ) unfortunately, I can’t do the same thing with the file that I already have (image below).
    I can’t bend it and change its shape. Should I apply some sort of mask and then change it ? I tried to look for tutorials on that and wasn’t very successful in that.
    Can you give me some advice on how to make it happen ?
    Gosia
    Mark Suszko replied 12 years, 3 months ago 2 Members · 3 Replies
  • Mark Suszko
    June 23, 2014 at 2:02 pm
    Grab a smaller piece of that film strip as a still, then drop it into a replicator, or the image well for your bezier path?
  • Malgorzata Wojtunik
    June 23, 2014 at 6:08 pm
    Hey,
    I am not sure if I understand well what you mean. I should grab a piece of this film strip and replicate it, but how can I transform it later on ? How should I make it from the rectangular strip to kind of an oval which is at the beginning of the animation ?
  • Mark Suszko
    June 23, 2014 at 11:16 pm
    the replicator can be made to push multiple replicated stills along a path you draw. You adjust the spacing between the frames until it looks like one continuous strand again.
