Activity Forums Apple Final Cut Pro Transform zoom-in S curves
  • Transform zoom-in S curves
    Posted by Gary Caganoff on May 10, 2015 at 11:37 am
    Wondering why my zoom-in is curving back and forth not following the path I thought I created in Transform mode. And how do I correct it?
    Thanks for your help!
    Mark Meredith replied 10 years, 7 months ago 2 Members · 1 Reply
  • Mark Meredith
    February 3, 2016 at 2:05 am
    Hey Gary, I hope you already found this solution.
    In case you didn’t, select your clip in the timeline, in the lower left corner of the Viewer, select the “Transform” option. Then select the keyframes displayed right on the viewer, right-click to change from linear to smooth. Change all keyframes to linear and that should make it all better.
