Activity Forums Apple Motion transform parameters
  • transform parameters
    Posted by Bill Parker on July 20, 2007 at 9:42 am
    I often need to add a keyframe to each of the transform parameters (scale, rotation, shear, position, and anchor point) at the same time. Is there a quicker way to set those key frames? Ideally, I would like to set them all at once and not have to set each one individually. Does anyone know a way around this?
    Edo Medicks replied 19 years ago 4 Members · 4 Replies
  • Noah Kadner
    July 20, 2007 at 3:38 pm
    Hit A to record keyframes automatically. On any adjustment to a parameter a keyframe will be created automatically.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Wayne Franklin
    July 20, 2007 at 3:48 pm
    If you’re not actually adjusting all of the keyframes, only keyframing some to their current values in order to initiate a change from that point, why not copy and paste control points from the previous keyframe (in the keyframe editor) and then adjust whichever parameters you choose?
    The cheese stands alone.
  • Bill Parker
    July 23, 2007 at 1:04 pm
    I do that to bring the photograph in, but if I want to have it pause for a few seconds before I send it off again, I need to manually set all the parameters and then hit A and then move the photo. Otherwise, when I hit A and move the photo, it starts moving immediately after it arrives. I can’t find a way to have two separate pairs of keyframes. I’m sure I’m doing something wrong. Does this make sense?
    Thanks.
  • Edo Medicks
    August 8, 2007 at 5:46 pm
    there should be a shortkey for setting keys, maybe K? i remember trying to do the same and being plauged by the Boomerang effect. using the graph you make a ‘flat’, beware… beware 🙂
    and all you want is a simple AE feature…
    The cup is half full and my shirt is half wet
