Activity › Forums › Adobe Premiere Pro › Transform mono tracks into stereo track
  • Transform mono tracks into stereo track
    Posted by Bayol Jack on September 8, 2015 at 6:20 pm
    I every body
    I’m writing from France so forget my lousy English
    I’d like to know how can I transform 2 mono tracks into 1 stereo track?
    Or how can I merge 2 mono tracks into 1 mono track
    Or how can I group 2 mono tracks so that I don’t have to change the volume settings on both tracks but only on one of them when mixing.
    Simon Billington replied 10 years, 12 months ago 4 Members · 4 Replies
  • Jon Doughtie
    September 9, 2015 at 5:42 pm
    Right-click your footage in the bin. Select “Modify”
    You can set up the audio channels of your footage to work however you would like them to work in the timeline. This must be done before you place the footage in the timeline.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Bayol Jack
    September 9, 2015 at 6:55 pm
    Thank’s this will help.
  • Robert Withers
    September 22, 2015 at 10:20 pm
    Jon and all,
    I would like to do the same thing but I have a fine cut sequence with 100+ clips in it.
    Is there a way to replace all the dual mono audio tracks in the sequence with modified tracks from the bin?
    Can I send the dual monos to submixes . . . and still edit length and transitions?
    Can I send tracks including submixes to Audition for equalizing, etc?
    I’m not turning up any info about this after extensive research.
    Robert
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • Simon Billington
    September 24, 2015 at 1:14 pm
    While the suggestions here will allow you to create stereo audio from two mono tracks, it won’t sound as its in stereo, it will still sound mono, but come out both speakers, it won’t actuall sound like it was recorded as stereo.
    That’s probably okay and what you want. I just want to make sure you are aware of that.
