Activity Forums Adobe After Effects Transform in After Effect
  • Steve Roberts
    March 30, 2006 at 4:57 pm
    Check the help under “parenting”. With it, you can transform one layer, and others will follow.
  • Mike Clasby
    March 30, 2006 at 4:59 pm
    Check out parenting in the Help files.
    In the parent Column (if not showing, right click any column (like source name) in the timeline box and Columns > Parent) pickwhip (the thing that looks like @) and drag it to the layer you want to be the boss), or choose from the drop down.
    Now any transformations to the parent will also effect the children.
