Activity Forums Adobe Illustrator transform handles have disappeared
  • transform handles have disappeared
    Posted by Indian_tut_guru on May 14, 2007 at 10:25 am
    hi
    i have illustrator CS2 installed on windows vista home OS.
    my problem is that recently my transform handles have disappeared. every time i have to scale down anything i have to use scale tool. no transform handles r appearing.
    how can i get ’em back.
    thnx in advance
    Luxman Akim replied 12 years, 6 months ago 5 Members · 6 Replies
  • Mike Gondek
    May 14, 2007 at 2:35 pm
    Try resetting your illustrator preferences. Since you said this used to work good chance this will be fixed.
    If you had a huge rectangle outside the canvas on your page, and you do a select all, it may appears you lost your transform handle, as they are just outside your view area. Most likley my first suggestion is your solution, but mentioning this as I once had someone in a class in that situation.
  • Indian_tut_guru
    May 15, 2007 at 11:07 am
    hi
    thnx for ur reply
    where should i reset my preferences. i went to file preferences but there is the option to reset warning dialoges.
    how to reset preferences in illustrator cs2
    regards
  • Mike Gondek
    May 15, 2007 at 1:21 pm
    Immeditely after booting illustrator hold down these 3 keys (Shift Ctrl Alt) until prompted about do you want to reset your prefs.
  • Melody Sandola
    June 4, 2008 at 3:28 pm
    Under View click on show bounding box. This was driving me crazy too!!!
  • Chris Fraser
    March 15, 2010 at 8:09 am
    Such a simple solution, this has been bugging me for years! Thanks!!
  • Luxman Akim
    March 7, 2014 at 3:19 am
    I think, to restore auto transform in illustrator as seen in the picture attachment sent it, you just press Shift + Ctrl + B or select View – Show Bounding Box. that’s it!
    I hope this can help
