Activity Forums Adobe After Effects Expressions Transform based on a greyscale value? How?
  • Transform based on a greyscale value? How?
    Posted by Peter Van den wyngaert on July 12, 2005 at 1:54 pm
    I’m looking for an automated way to transform the scale & rotation of multiple layers (I’m talking 50 to a hundred here), based on one hidden layer containing a greyscale (or alpha) composition.
    Can this be achieved with expressions?
    I want to animate a dotted text (word made up by individual dots, each dot on it’s own layer), by using just one greyscale/alpha comp which transforms them (scale rotate opacity, whatever).
    Any other ideas besides the expression or multi layer setup in order to animate the dots are also welcome.
    Mike Clasby replied 21 years, 1 month ago 2 Members · 1 Reply
  • Mike Clasby
    July 12, 2005 at 8:08 pm
    I think Simulation>Card Dance will do what you want.
    Search AE Help for “Card Dance”, be sure an look at the “Understanding Card Dance” page as it explains how a grayscale layer controls the cards.
    I think you should create the Dot Text you want then animate it with card Dance, then time reverse the layer to get you text to assemble from
    a series of flying dots. Card Dance has a 3D camera in the plugin so you can fly around and through your dots.
