Activity Forums Adobe After Effects transform animation jitter….please help!!
  • transform animation jitter….please help!!
    Posted by Pixel8ted on December 22, 2005 at 5:37 am
    Hi Guys,
    When animating simple masked shapes/or even imported illustrator files in after affects 6.5 pro, and on viewing the resultant animation closely/carefully :), the ram preview shows jittery edges aroung the shapes, the motion is not silky smooth, ease keyframes, motion blur do reduce this effect, but does not completly eliminate it!!
    I find that position, and rotation animations on vector shapes against contasting backgrounds bring out this probelem very clearly…?but in some cases , comps with low contrast and blurred edges do show this slight
    jitter on the edges too, but I need to watch the animation carefully?
    Finally I find that medium paced transform animations are the most affected, very fast moves or very slow moves seem not to show this probelem?!!
    please advise , am i doing something wrong in my animations, or have I missed some important preference/setting in ae?
    my system spec.pentium 3GHz\2GB Ram …
    Thanks.
    Joel Arvidsson replied 16 years, 1 month ago 4 Members · 4 Replies
  • Jim Kanter
    December 23, 2005 at 3:10 am
    Have you activated Continuously rasterize/Collapse Transformations switch on vector content?
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Pixel8ted
    December 23, 2005 at 5:25 am
    Yes…but What I really meant was animating shapes with relatively sharp edges…
  • 305artist Create COW Profile Image
    305artist
    November 15, 2006 at 11:58 pm
    Did you solve this problem? I am having the same problem but with bitmaps!
  • Joel Arvidsson
    August 4, 2010 at 6:12 pm
    I get this some times to and its very enoying. Not like anybody normal would notice but you can se it clearly.
    joelarvidsson@gmail.com
