Activity › Forums › Adobe After Effects › transform animation jitter
  • transform animation jitter
    Posted by Joel Arvidsson on August 4, 2010 at 6:23 pm
    Sometimes when you animate or track something the text or loggos gets an small jitter. Is it just something to live with? Its not that bad so a normal person would think of it but its pretty enoying to me. Whats you best trick to make it smooth. I think its more in slow paced animation you se it where you dont have any motionblur to hide under.
    It the same for both bitmap and vector loggos (of course the are collapsed).
    Anymore have this thougts?
    joelarvidsson@gmail.com
    Joel Arvidsson replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    August 4, 2010 at 7:14 pm
    It sounds like you are experiencing issues with interlacing. The edge of your graphic has a sharp edge and the upper/lower field issues cause the edge to jitter.
    Assuming all your render settings are correct, couple things you can try, move your grx up or down 1 pixel, sometimes that can help a bit. Another thing to do is apply the effect Blur>Reduce Interlace Flicker. Usually a value of 1 or 2 will take care of the problem.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • Joel Arvidsson
    August 4, 2010 at 7:46 pm
    It actually helpt alot. I usally use an boxblur and just 0,2 and it looks good in ae. But in final cut its the same old artifact. But with Reduce Interlace Flicker set to 1 its looks more decent. I think 0.2 might been to low for fcp. Anyway was a really good tip of an small artifact that bugs my eyes. Since i work in progressive i didnt think of using the Reduce the interlace flicker but the plasma outputs 1080i. Doh!
    Joel
