Activity Forums VEGAS Pro Transferring Vegas settings + customized interface & toolbar through different user accounts
  • Transferring Vegas settings + customized interface & toolbar through different user accounts
    Posted by Carlos Silva on January 3, 2015 at 10:42 pm
    I opened Vegas from a just created user account and none of my settings/interface tweaks & toolbar customization from my other user account have appeared.
    Then I copied the following folder content from one user to another:
    C:/Users/Cadu/AppData/Roaming/Sony
    Among others, there is the subfolder:
    C:/Users/Cadu/AppData/Roaming/Sony/Vegas Pro/13.0
    Nonetheless, nothing has happened.
    Would it be possible to transfer Vegas settings + customized interface & toolbar through different user accounts?
    Many thanks,
    Cadu
    Russ Froze replied 11 years, 7 months ago 2 Members · 3 Replies
  • Russ Froze
    January 4, 2015 at 5:21 am
    Hello Cadu,
    Try Preset Manager for Vegas the download url is,
    https://www.sonycreativesoftware.com/download/utilities
    It is near the bottom of the page.
    As to your custom layouts they will need to be moved manually, I believe although I could be mistaken.
    C:\Program Files\Sony\Vegas Pro 13.0\Standard Layouts
    There was some other stuff but it escapes me right now, perhaps I’ll remember later but this should get you started.
    Russ Froze
  • Carlos Silva
    January 6, 2015 at 3:24 pm
    Hi Russ,
    Thanks for your reply.
    Actually, I could achieve the customization transfer through the process described below, which was informed by the Vegasaur support (by the way this is a handy tool for Vegas and the guys there are quite attentions with users!)
    “Vegas stores toolbar customizations in the file tbmappings.dat, under C:\Users\username\AppData\Roaming\Sony\Vegas Pro\13.0\
    You must also copy this registry key (otherwise this doesn’t work): HKEY_CURRENT_USER\Software\Sony Creative Software\Vegas Pro\13.0\Metrics\Application\B300
    Close all copies of the program before you copy the files!”
    So I did the following to achieve the transfer:
    a) From windows search type ‘regedit’ (withouth quotes) + Enter.
    b) From the regedit left pane navigate to: HKEY_CURRENT_USER\Software\Sony Creative Software\Vegas Pro\13.0\Metrics\Application
    c) Right click on the “Application” folder and “Export”. This will create a REG file with the settings (choose where to save in order to be accessible to other user accounts and/or different computer).
    d) From the other user account and/or computer just double click the file. The magic is done!
    Best,
    Carlos
  • Russ Froze
    January 7, 2015 at 3:19 am
    See I told you there was something else I’d forgotten, the registry stuff, yea that was it. Glad you worked it out.
    Russ Froze
