Activity › Forums › Apple Final Cut Pro Legacy › Transferring QT file to USB stick
Posted by Coulter Mitchell on February 25, 2010 at 5:37 pmI am trying to put a 6 gig qt file of 720p video on a usb stick. One usb stick is 8 gigs and one is 15 gigs. Both times it says it will transfer for 20 min and then i get an error message. I’ve tried exporting from qt and dragging from desktop or saving the file to the stick and and it always says error. Anyone know how I can transfer this file? Thanks.
John Pale replied 16 years, 7 months ago 4 Members · 7 Replies -
John Pale
February 25, 2010 at 5:42 pmSounds like your USB stick is formatted FAT32, which has a 4GB file size limit.
Use Disc Utility to reformat it as MacOS Extended.
David Roth weiss
February 25, 2010 at 5:49 pm[John Pale] “Sounds like your USB stick is formatted FAT32, which has a 4GB file size limit.
Use Disc Utility to reformat it as MacOS Extended.”
Yep, they all come formatted FAT32 from the factory.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Don Walker
February 25, 2010 at 6:51 pmWould formatting a jump drive NTFS make it so it could hold large files and be seen on Macs and PCs?
Don WalkerJohn 3:16
David Roth weiss
February 25, 2010 at 6:58 pm[Don Walker] “Would formatting a jump drive NTFS make it so it could hold large files and be seen on Macs and PCs? “
Not without a plugin installed such as Tuxera. Normally, NTFS is read only on Macs.
So, without Tuxera or and equivalent plugin, you could transport files to your Mac with NTFS drive, and you could playback copy off that drive, but you could not copy to the drive or use it to transport to a PC.
If you search the FCP Forum for Tuxera, you will see that someone posted a freebie alternative to a post I made recently. I know Tuxera works, I cannot vouch for the other plugin.
David Roth Weiss
John Pale
February 25, 2010 at 6:58 pmMacs cant write to NTFS volumes without additional software. They can read from them.
you can try this…
https://www.tuxera.com/products/tuxera-ntfs-for-mac/
Or you can get MacDrive for the PC which can let it read MacOSX Extended drives.
David Roth weiss
February 25, 2010 at 7:16 pmJohn,
You’ll need some more caffeine to beat me to the punch… 🙂
David (aka – energizer bunny)
David Roth Weiss
John Pale
February 25, 2010 at 7:52 pm[David Roth Weiss] “You’ll need some more caffeine to beat me to the punch… 🙂
“Off to Starbucks!
