Activity Forums Apple Final Cut Pro Legacy Transferring Premiere Pro timeline to FCP?
  • Transferring Premiere Pro timeline to FCP?
    Posted by Daniel Grixti on August 8, 2010 at 1:14 am
    Hi there,
    I have a completed 5 min edit on Adobe Premiere Pro CS3 (PC) that I would like to transfer to FCP (Mac) to re-edit.
    Is there any way to do this? Any help would be much appreciated.
    Dan
    Dennis Radeke replied 16 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 8, 2010 at 1:22 pm
    Export an EDL from Premiere and import that to FCP. Recapture in FCP…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Dennis Radeke
    August 10, 2010 at 11:22 am
    Assuming you don’t want to purchase CS5 which supports FCP XML export, I would try downloading a trial of Premiere Pro CS5, import a COPY of your CS3 project and then see if you can export FCP XML to finish.
    Hope this helps.
