Activity Forums VEGAS Pro transferring large files to portable drives
  • transferring large files to portable drives
    Posted by Codyjarrett on October 1, 2007 at 11:19 am
    I’m trying to transfer a high quality MPEG-2 file (4.7 GB’s) to my 80 GB Lacie Portable Drive.
    When I try the transfer, the message reads the drive is full, even though it’s empty.
    Is there something on my computer (HP 4400 work station running Windows XP) that I must adjust so that I can transfer large files like these?
    thanks!
    Larry Brewer replied 18 years, 10 months ago 4 Members · 4 Replies
  • Douglas Spotted eagle
    October 1, 2007 at 1:43 pm
    Format the drive using NTFS instead of FAT 32. Most off-the-shelf external HDD’s are preformatted for FAT 32. You can convert an existing FAT drive to NTFS.
    Douglas Spotted Eagle
    VASST
    Aerial Camera/Instructor
    Certified Sony Vegas Trainer
  • Codyjarrett
    October 1, 2007 at 2:34 pm
    Thank you.
    I will try re-formatting the drive and attempt another transfer of the file.
    I appreciate your help.
  • Terje A. bergesen
    October 3, 2007 at 6:21 am
    Just for the record, you don’t need to re-format. The command convert /FS:NTFS will do the trick. Quickly too.
  • Larry Brewer
    November 6, 2007 at 7:14 am
    I had a very bad experience with a USB portable drive that I purchased and “quick formated” to NTFS. I believe this is equilant to convert/FS:NTFS. It was unstable and made a habit of going off line from time to time. Then one day it just quit. Did not show up as a drive in “My Computer”.
    I restored it with Restore 2000 software and copied the contents to a different drive. I then reformatted (the slow way) the orig USB portable drive to NTFS and it has been stable and usable ever since.
    I think the problem with the quick format is that it doesn’t detect and mask bad sectors.
    I use several USB external HDDs and I take the time to completely format them to NTFS before I use them in my system.
    Of course, I’m paranoid and that may explain some of my issues.
