Activity Forums Adobe After Effects Transferring fron VHS to dv
  • Transferring fron VHS to dv
    Posted by Taneil Adams on June 9, 2008 at 7:39 pm
    I don’t have the money for a transfer house. Is there a way to tranfer from vhs to dv with the equipment I have at home? I have a dual vhs/dvd player and camera with cables. Sorry I didn’t see a forum for this topic. It will be imported into AE though.
    Ta Neil Adams
    Film maker/videographer
    “It is certain, in any case, that ignorance allied with power, is the most ferocious enemy justice can have.”
    -James Baldwin
    https://anewbeginningproductionz.typepad.com/introduction
    Joey Burnham replied 18 years, 3 months ago 4 Members · 3 Replies
  • Ron Coy
    June 10, 2008 at 12:18 am
    usually, the cables from the camera are output only. Some cameras allow you to capture analog sources to DV, so check your specs on your camera.
    If not, you can get a converter for analog to DV conversion. They are about $100 for a low end one, and can get very expensive.
  • Chris Wright
    June 10, 2008 at 1:03 am
    If you have a sony camcorder, you can simply plug your VCR into its rca plug and export directly to dv firewire premiere pro capture.
  • Joey Burnham
    June 10, 2008 at 6:20 pm
    where are you located?
