Activity Forums Apple Final Cut Pro Legacy Transferring footage from Compact Flash Cards
  • Transferring footage from Compact Flash Cards
    Posted by Daniel Garriga on May 2, 2011 at 4:01 pm
    Hey all quick question,
    Currently on a shoot now as a DIT transferring footage via compact flash cards from the nanoflash unit.
    My question is, is it safe to transfer each card to two hard drives that are daisy chained at the same time or transfer to one drive and then once completed transfer to the back up. I have been doing the latter worried transferring to two drives at once will mess something up.
    Rafael Amador replied 15 years, 4 months ago 3 Members · 3 Replies
  • Cody Walters
    May 3, 2011 at 10:19 pm
    How are you transferring your files over? It sounds like a thing you wouldn’t want to do. I haven’t done this before with daisy-chained hard drives, but I would use something like Shotput Pro and have it copy to both hard drives and verify the copy. I know that daisy-chaining them will cause the transfer to be slower.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videos
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Daniel Garriga
    May 6, 2011 at 12:16 pm
    I was using a compact flash reader via USB and simply dragging and dropping all the files to a G Raid drive and then once done i dragged and dropped again to a lacie rugged for back up.
  • Rafael Amador
    May 6, 2011 at 12:27 pm
    Withe a USB connexion you better do one HD at a Time.
    rafael
    http://www.nagavideo.com
