Activity › Forums › Apple Final Cut Pro Legacy › Transferring files to Premiere on PC
  • Transferring files to Premiere on PC
    Posted by Richard Martz on May 12, 2010 at 3:57 pm
    I recently finished a program on FCP7 that originated on HDV/1080i. The client now wants copies of the original camera masters. They are running Premiere Pro on a PC. I’m not sure what version they are using. How do I get them this material?
    I wanted to just put it all on a firewire drive but they wont be able to read a Mac-formattted drive, will they? I could just put this footage on a SATA drive but I’ll have the same problem. I’m thinking I put a firewire drive on another PC on my network and just transfer the footage to that drive. Any other ideas?
    Also will they have any trouble reading the FCP7 HDV files I give them when they open them in Premiere?
    FCP 7
    MAC 8 core
    BlackMagic Studio Pro
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
    Shane Ross replied 16 years, 4 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    May 12, 2010 at 4:42 pm
    Was tape shot? You could dub them?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Richard Martz
    May 12, 2010 at 4:51 pm
    Yes but client does not have access to HDV playback equipment.
    FCP 7
    MAC 8 core
    After Effects
    PhotoShop
    Illustrator
  • Shane Ross
    May 12, 2010 at 5:03 pm
    [Richard Martz] “Also will they have any trouble reading the FCP7 HDV files I give them when they open them in Premiere? “
    Yes, they will. That codec they are captured too is only viewable if you have FCP. Or a third party decoder.
    #48 – Cannot view DVCPRO HD or HDV or ProRes on my computer.
    Shane’s Stock Answer #48 – Cannot view DVCPRO HD, HDV or ProRes QT files on your computer.
    The DVCPRO HD, HDV and ProRes codecs only comes with FCP. If your computer does not have FCP installed, it cannot view these quicktime files. It doesn’t matter if it is a Mac or PC, without FCP installed, you cannot view these files.
    If you need to view ProRes material, you can download the ProRes decoder (mac and windows compatible) for ProRes
    https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Windows.
    https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Mac
    If your footage was captured as DVCRO HD you can buy the Calibrated DVCPRO HD decoder:
    https://www.calibratedsoftware.com/QDVCProHD.asp
    HDV, XDCAM? Calibrated has you covered too:
    https://www.calibratedsoftware.com/QXD.asp
    If you have MXF files from a P2 camera and you need to view the footage on a computer without FCP, you can download P2CMS from Panasonic:
    https://www.panasonic.com/business/provideo/p2-hd/downloads-and-updates.asp
    Or you need the other party to compress the footage into a format your computer can play, like H.264.
    Shane
  • Dennis Radeke
    May 13, 2010 at 2:15 am
    They can get MacDrive and read your drives no problem.
    Shane is right about FCP HDV – it’s only if you have FCP.
    Shane and I may respectfully disagree about needing the ProRes decoder. We chatted on it once before and it’s unclear, but my belief is that the ProRes decoder is in later versions of Quicktime 7 for PC.
    My suggestion is to convert the material to ProRes and give it to your client that way. Premiere Pro can playback ProRes material in CS3 and above (Mac or PC). With the latest version of CS5, the performance on ProRes should be very good.
    Hope this helps,
    Dennis – The Adobe guy
    https://blogs.adobe.com/genesisproject/
  • Shane Ross
    May 13, 2010 at 2:17 am
    GAH! I gotta change the stock answer. The ProRes Decoder is part of FCP 7.6.
    Thanks Dennis
    Shane
