Activity Forums Avid Media Composer Transferring files to different HD
  • Transferring files to different HD
    Posted by Henning Tveito on June 8, 2011 at 5:43 pm
    I need to copy 400GB of files to a new hard drive, including the Avid project. I’ve had some issues with that earlier…
    I will not be using the current HD anymore after everything’s copied.
    How can I do this and still be able to open everything with no media being offline after it’s copied?
    I know it’s got something to do with the transcode/consolidate function… if someone could give me a step-by-step walkthrough, I’d be ever so greatful 🙂
    Jeff Greenberg replied 15 years, 2 months ago 3 Members · 2 Replies
  • Ed Cilley
    June 10, 2011 at 6:10 pm
    Let me see I understand your set-up: media is on an external drive adn you want to copy all the media to another drive.
    Copy the entire Avid MediaFiles folder to the new hard drive. Make sure there are no Avid MediaFiles folders on your internal HDD. Disconnect the old drive, start MC.
    One program that is great for helping search for media on all volumes is Media Mover.
    https://www.randomvideo.com/products/mediamover_avid.html
    Hope that helps
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Jeff Greenberg
    June 12, 2011 at 5:48 pm
    Open the media tool. Select all the clips for this project from all drives.
    Clip menu: consolidate/transcode.
    Consolidate all the clips to another drive.
    One option – ‘delete’ will delete the original media. The project will be hooked up to the new drive. Copy the project (at the desktop level) and go.
    Second option – don’t choose delete. When you do this, you’ll have two copies – the original and the new media.
    If you choose relink selected clips to target drive, the project will connect to the new drive (and it will rename the original media as .old.)
    If you don’t choose relink, it’ll keep it’s existing links on the existing drive and create .new media on the new drive. When you copy the project and put it on computer #2 – you’ll have to ‘relink’ it.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
