Activity › Forums › Apple Final Cut Pro Legacy › Transferring Adobe Premiere Project to Final Cut Pro
  • Transferring Adobe Premiere Project to Final Cut Pro
    Posted by Devin Tanchum on April 22, 2011 at 7:44 pm
    Hi All,
    I have inherited a project originally edited on Premier on a different computer which I will be continuing to work on in FCP 7.
    The source footage was captured as .mpeg and I would like to figure out a way to sacrifice as little quality as possible.
    I’ve seen similar posts before here that suggest using XML, however those posts are for people switching between Premiere and FCP on the same computer and my fear is that FCP is not going to like the .mpeg formatted source files. The editor who had worked on this project before me determined that exporting as .M2V was the way to go, but in my opinion that is totally crazy.
    Looking forward to your help.
    Devin
    Vidya Ranya replied 12 years, 8 months ago 4 Members · 4 Replies
  • Walter Biscardi
    April 23, 2011 at 12:35 pm
    Premiere literally has an “Export to Final Cut Pro” command now. If that version doesn’t, then Export XML and open it in FCP.
    Now the huge advantage that Premiere has over FCP is that it can edit MPEG, H.264 and other file formats that FCP cannot. So your only option is to convert any and all files that FCP cannot edit with.
    I had to do that recently with a major project that was sent to us in Premiere. It was all edited with the raw MXF data from the P2 cameras and with a ton of H.264 files. I had to convert everything to ProRes before I could pick up the edit.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    Blog Twitter Facebook
  • Devin Tanchum
    April 26, 2011 at 5:34 pm
    Thanks for your help, Walter. In truth, I don’t even need to edit this project any further, however I do need a high-res export for archival purposes that will look good in QT. Any hints for a Premiere export setting that will look good when I convert to Apple ProRes?
    Thanks.
  • Dennis Radeke
    April 28, 2011 at 10:56 am
    If you’re Premiere Pro install is on your Mac, then export to ProRes directly from Premiere Pro. Create a custom preset using ProRes (save it) and export away.
    Good luck,
    Dennis
  • Vidya Ranya
    January 17, 2014 at 7:39 pm
    Hi sir,
    Can you please explain how you convert MXF files to work easily in FCP and also please help me to convert MTS files to work in FCP.
    Thank You
    J Vidyaranya
