Activity › Forums › Apple Final Cut Pro Legacy › Transferring A project from Avid MC 5 to FCP 7
  • Transferring A project from Avid MC 5 to FCP 7
    Posted by Matthew Edwards on November 30, 2013 at 9:20 pm
    Hi Guys! I was recently given a avid media composer 5 project and told to put it into Final cut pro 7 for the final edit. The avid edit was done on mac and I know i have heard that it can be done! I have tried looking at other posts on here and decided to get the automatic duck for fcp and so far it can import the sequences and time lines very well! My problem is that all the media goes offline and when i try to relink the media it either says that its not the right media or when i do reconnect the media it says Failed to load.
    Is there something i am not doing? I am exporting the .aaf from avid and sequence codec is xdcam because it was all pretty much shot on the sony ex3 and selecting link to don’t export media. I have also tried it with consolidate media but still the same problem. Wondering if anyone out there has had this issue and was able to resolve it? I have included some images of my settings for export.
    any help would be very appreciated!
    Thanks so much in advance!
    Matthew
    Matthew Edwards replied 12 years, 9 months ago 2 Members · 5 Replies
  • Rainer Wirth
    December 1, 2013 at 8:32 am
    I think your problem lies in the XDcam media files. For FCP you need XDcam transfer to edit in FCP. I think Avid works natively with XDcam media files. So for FCP you have to transfer the XDcam files first with the exact names to relink. FCP refers mostly to names, Avid mostly to Source timecode and tape.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Matthew Edwards
    December 1, 2013 at 7:23 pm
    Hi Rainer! Thanks for the quick reply! I wonder is there any way to export the media from avid as a quicktime with the same names? Or do i have to go through xdcam transfer? it has already been logged as different names and reconnecting all the files individually will take a huge amount of time since it is a huge project with tonnes of clips. The import with automatic duck actually went really really well! All the edits are there and everything! it only is just not letting me see the clips as a full and not being able to connect to them show them as a offline clip. Thanks so much I am really trying to figure this out and i really appreciate the help!
    Matthew
  • Rainer Wirth
    December 2, 2013 at 9:09 pm
    Hi Matthew,
    to me you have to go through XDcam transfer. FCP needs the proper names of the clips for relink
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Matthew Edwards
    December 4, 2013 at 12:02 am
    Thanks so much Rainer! Here what I ended up doing:
    I reimported the ex3 footage using log & transfer. Then I took all the capture scratch files and used compressor to convert them into apple pro res 422. Reconnected all the files from the automatic duck import to the pro res ones and now they are working great and everything is there! The only problem is that even though all the footage is in pro res and so is my sequence codec it still un renders it self every time I make a cut. Is there something I did wrong? Thanks again you guys have really helped me out!
    Cheers
    Matthew
  • Matthew Edwards
    December 4, 2013 at 7:52 pm
    Update: I have input all footage using xdcam
    Transfer and log and transfer but there is still a bunch of audio files that just aren’t there! Is there a way to export the audio from avid to use in fcp?
